Real Spring Fet Reverb (Surfybear)
Elijah-Baley
Hello everybody,
This pedal: https://www.surfyindustries.com/surfybearmetal
«The same specifications of the Fender® 6G15® reverb unit, replacing the tubes with JFET transistor technology.»
«Initially produced as a DIY kit, this was the schematic.» But discontinued. https://www.surfyindustries.com/faq-diy-kits
SurfyBear.png IMAGE SCHEMATIC
(Q1 transistor not labeled, but should be a BC557.)
This version, with the tremolo, includes extra controls: Mixer 1 and Mixer 2 swapped each other through a footswitch. (I'll pass over the optional external reverb tank connection.)
Here's the instruction from the official link.
Also Decay and Volume control has been added.
About the Volume, I heard someone tell that the reverb has a lot of volume, so that could be just a master volume placed somewhere to attenuate it when the reverb is at higher setting?
I have no hint about Decay control.
Here's the Ricochet (not 1:1) clone by Griffin Effect https://griffineffects.com/byo-pcbs/modulation/ricochet-pcb. But its R15 value is wrong, the right value is 1.5R.
PSU is always for me a problem when that is not the standard 9v Boss style. I have to find a 12v 1A, I guess. Polarity never mind, I mean, I could invert the wire on the DC jack.
I would like to build the circuit on veroboard, and insert all in one big enclosure, I'll see what kind. The circuit in an aluminum box to shield it for sure.
What do you think about a project like that?
Not sure the jfets would have enough current drive. Maybe I'm wrong. Mosfets would fs. Otherwise you could drive the springs with parallel opamps, BJTs or a dedicated pwr amp ic then include fets in the front end and feedback loop.
Now that I've looked a little closer. Mosfets are being used to drive the spring. The dwell control just seems level.
this one uses a TDA7052B to drive a mini accutronics tank.
there's a veroboard layout available for the above project (spaceman orion/hooke).
fits in a 1590J.
i reckon it sounds pretty good. (build thread w/ demos)
The Spaceman Orion/Hooke seems ok. I'm not sure it has the same presence and all the "wet" of the Surfybear.
Anyway, I would like something more similar to the Surfybear, and we have the basic schematic. I could even try to drawn a layout by myself.
But I'd like to consider some mods, too. Those extra controls, for example.
NE5532 will easily drive most reverb tanks, and plenty of schematics out there for full send/return circuits with all controls included.
are you wanting to run the tremolo in series with the reverb or go parallel like the weber revibe?
I didn't considering to run the tremolo in parallel. I was thinking to put it in front of the reverb.
Actually, in this project I was thinking about the Jordan Vico Vibe, that I built it in a pedal a few of months ago, so I know it, and I like it enough.
The only difference is that I will have to supply also the Vico Vibe at 12v, so I guess I could change something in it, but maybe we could talk about the tremolo section later. :)
I did a PCB for this ijn KICAD and never got time to finish. I have a project file of the one I made prototypes for (with some errors) and a never one with the errors (I think fixed). If anyone wants the files etc your welcome to it. The below is my version 1 with errors - I stupidly had a mosfet flipped and left off a 100uF. The board can be jumped / fixed but like I said I lost steam and interest.
Thank you. I saved the schematic, even if I guess that is the stock, apart the trimmer.
Could you remember me what the trimpot do? Stock resistor value is 47k.
I'm still searching some schematic that includes a decay control and see where I can place it in this schematic.
The RV3 trimpot is supposed to be adjusted so the TP1 (testpoint) is 6V. This site used to sell PCBs and has a schematic, parts list, and writeup.
BTW - here's a really simple spring reverb circuit (you could probably add controls for dwell etc) from an old PEAVEY amp. Uses a higher impedance tank for their teeny little tank but you can use a better nice sounding tank like a MOD 8EB2C1B Reverb Tank 800/2200 ohms.
You'd want to redesign for lower voltage etc but maybe it gives someone ideas etc.
Hi @lcipher3, I'm searching for a good project of a good surfybear reverb to build for my son and I've seen yours, which seem the very best of all I've seen until now. Can share your files?
Thank you very very very much!
p.s. I've already got IRF9530 and IRF530, can I use them instead of 9510 and 510? There are modifications to do?
Thank you again
Max
