Recommended Potentiometers
jallenyoung
Anyone have a recommendation for potentiometers for the PCBs?
All the pedals I've built in the past have used Alpha pots, but they are far too small for the PCBs here.
Thanks in advance!
Also make sure you get the 6.35mm shaft linked above, sometimes there's a 6mm shaft version that looks the same. Most knobs made for guitar pedals are 6.35mm shaft and if you put that on a 6mm shaft your knob will turn off-center. I don't think these types of pots come in D-shaft but definitely never get those, then you can't ever rotate the knob to line up exactly with the orientation of your enclosure, any graphics that might be around the knob, etc.
