Relay Bypass Module Questions
himers1990
Hello.
I want to put effects A and B in one enclosure.
Use one relay bypass module to switch between A and B with one switch, and also do this with a remote switch.
Which relay bypass module should I use to accomplish this?
How do I wire effects A and B and the relay bypass module?
Any suggestions or advice would be greatly appreciated.
maybe you can use 2 latching relay bypass boards like this:
they would have to bet setup with one on and one off and would swap when a switch is activated. They should be non latching two pole switches
***MIGHT WORK*** not sure. There may be a smarter way. You might be able to do it with a single 3pdt switch but no remote switch
So you want to toggle between Effect A and Effect B with a single footswitch?
Do you want to be able to bypass both effects?
