fav13andacdc
Hello all,
I have what is hopefully a quick question. I am building the Taqueria Overdrive, and I am modding the gain toggle to use an RGB LED with a DPDT Footswitch (Blue for normal, Red for High Gain) I got the idea from Reddit, but it seems the user made it more complicated than it needs to be. Can I just wire lug 5 of the DPDT to the anode pad and the common cathode of the RGB LED to the cathode pad? I'm using a 3PDT Breakout board. I assume I wouldn't need an LEDR either in this case as CLR is already in the circuit.
