Seabed Delay with space for an extra 10K resistor
luisfernicho
I am building a Seabed Delay and noticed there is space in the PCB for an extra 10K resistor which is not reflected in the build document. Does anyone know if this 10K resistor is necessary and if not necessary, do I need to close the circuit by adding a jump wire where this resistor should be?
Here is a picture of the PCB with the drawing of the PCB from the build doc. Thanks in advance for any suggestions.
For the " I wanna play it now" answer, I'd say put it in. Your right, it's not in the doc., and IME, the pcb rules over the doc. If it turns out you don't need it, just clip it of the board. I'm sure someone that knows better will be along shortly...
