Crash102
Hi all, thought id post here as I’m getting near the end of things I can check and I’m to the point of going though every single resistor to check if that’s where the issue it
The pedal works (ish) , the led works, it even passes a fuzz sound.
However, the signal works best with the low notes and only if I dig in to them. Higher notes seem to die right away.
I’ve switched out the footswitch, the jacks, the transistors,
I’ve scrubbed the board clean
I’ve gone back and reflowed every joint.
I even tried de-ox it on the pots
I suspect it’s either a wrong resistor or maybe a faulty pot,
Just thought I’d crowd source it, as I this seems like it should be one of the easier ones to build.
