Hello, I have completed a Prismatic EQ pedal from effectslayouts.com. I am getting no output through the jacks. I have tested the power supply and that is working fine. I have made an audio bypass so that I can test the component connections. All the components are giving out a signal, although the signal is very weak. Of note, this bypassed signal is effected when adjusting the potentiometers. I don't even know where to start figuring out what is wrong. I've checked all my solder joints and used different power jack and input/output jack.
Anybody have a suspicion of what I've done wrong? I've done 10-15 builds and I've never had this issue before.
Thanks in advance.
Thanks in advance.
