Silent uberfuzz
ElfKicker
I’m stumped. I thought this went together really well but it’s completely silent on the auditorium. I get nothing with the signal probe beyond one side of r1. I replaced r1 and double checked the values of r2 and r7 (all of the resistors actually). Any ideas?
(NB My diodes match the board screen and square pad orientation but I noticed afterwards that the build document has one reversed. )
View attachment 128591View attachment 128592
which transistors did you use?
(can't see the model numbers in your pics...)
Q1-3 are 2n3904 hfe 336, 324, 319 4-6 2n5551 147, 147, 144.
this is your problem.
this PCB calls for 2SC series transistors, which are ECB pinout as @jwin615 has alluded to.
it appears your build has employed all EBC pinout devices (3904, 5551) - this isn't going to work.
if you replace these with 2SCxxxx transistors (or something with ECB pinout) in an appropriate gain range (2SC1815 are great for these), your build should work fine.
