keyth72
I wanted to share this in case anyone else finds it useful. I had an existing Tayda Drill template that I wanted to add UV print artwork to using Adobe Illustrator. In order to make an accurate layout of the controls I needed to convert the xy coordinates from the center origin (Tayda) to a top-left origin (Illustrator, and I assume most graphic design products). This is a simple spreadsheet which calculates that for an overdrive pedal I'm working on. You'll need to put the total x/y width height of the canvas for your enclosure (this one is a 1590bb), and then input the x/y in millimeters from your Tayda Drill Template. The X/Y will then be calculated in the right hand box, and entered into placeholder objects to define your layout in Adobe Illustrator. I added columns for the drill hole and component diameters for reference.
Not sure if anyone else uses this kind of workflow, but it saved me a bit of time and was easy to put together. Enjoy!
The forum doesnt allow excel files as attachments (probably for good reason) so I uploaded it to one of my Github repos, you can follow the link and click "raw" to download the spreadsheet:
This is what it looks like:
GuitarPedalPCBs/tools/TaydaDrill to Adobe Illustrator xy coord.xlsx at main · GuitarML/GuitarPedalPCBs
Collection of KiCad circuit board designs for guitar pedals you can build yourself. - GuitarML/GuitarPedalPCBs
github.com
