jesseando12
Hi
I am thinking that using the channel switching mode on the Intelligent Relay Bypass module could achieve a soft switch bypass for a buffered effect (e.g. Kliche, informant...) if wired like the buffered bypass is the "second channel."
Would this work? Has anyone tried it?
I assume adding a DPDT switch in the bypass loop could remove the buffer if desired.
Help appreciated!
Cheers
Help appreciated!
Cheers
