I have the Kings Hand V2 on the bench right now. Running into some issues that I'm trying to work my way out of. Not the PCB but that fact that I'm trying to use it in a combo build in a 1590BB. Not recommended, this V2 board really needs a 125B (as I'm finding out). But since I already drilled my enclosure I'm determined to try to make it work, we'll see. Not sure when it will be officially released but
@PedalPCB sent me one in advance. Part of the reason I love this place and prefer to give him my business whenever I can. Just a great customer centric business.
Re: Gibson, it depends on what model. I know the R series Custom Shop LP's and ES's are all wired period correct depending what year it's supposed to be. Not sure about their off the rack LP Standards, if I were to guess I'd say no, not 50's wiring but "modern" wiring which seems to be the standard for most companies, PRS included. The Duncan 59 and Thornbucker combo sounds pretty awesome. The Duncan 59 probably my favorite "big brand" humbucker and I've heard so many people rave about the Thornbuckers. I'm a big fan of "vintage output" pickups. I remember reading about Pete Thorn influencing John Suhr when they were designing the pickup. All of Suhr's other HB's tend to be higher output. Pete's argument was that with all the boost and drive pedals, not to mention high gain amps, the handicap of a lower output pickup is moot. You can pretty much dial in just about any level of output you want. However, what you can't do with high output pickups is recover the "character" that's lost when it's wound too hot. I pretty much agree with that. The 58/15 Low Turn pickups in my PRS 594 follow this philosophy and are awesome sounding pickups. I have the Lollar Low Wind Imperials in my Semi hollow and they are also fantastic sounding to me.
I am not a huge fan of splitting coils on HB guitars as it's neither fish nor fowl to me. I never use the coil split sounds on my PRS. But I can also see the advantage of it for a gigging guitar and being able to get the most sounds out of the least amount of gear. But in my case and for my applications if I want a single coil sound I'd just pick up a Strat or Tele. I'm blessed to be able to have access to a lot of different guitars (and it's my standby excuse to convince my wife that I need yet another guitar....."but honey, it's a sound I don't have in my portfolio that I "need"
) I'm not familiar with the DGT wiring but I do occasionally lust after one. I don't care much for the jumbo frets but otherwise those are spectacular guitars.
Hmmm the dummy coil idea is interesting. I'm pretty sure Eric Johnson uses stacked Dimarzio single coil in the bridge position of his signature Strat guitar with one coil disabled. I generally don't have too much problem with single coil hum because I don't play at loud volumes and I usually ground the crap out of everything in my guitars. I've also recently started using shielding paint in the pickup cavities and really like the results. Here's a recent
Tele build I just posted about yesterday. Super quiet guitar, I'm impressed. I just shielded the cavities and did not bother to run a dedicated ground wire to the jack. It's really quiet, I'm thinking about re-doing my other Tele's and Strats with it. It doesn't impact the tone like copper tape shielding does.
Re: experimenting with the 50's wiring. One idea is to make a cardboard template to hold the potentiometers out of the guitar. Then just use test leads to hook up the pickups and see how it sounds. You can try it both ways (50's and Modern) and mess with different caps before committing to solder (and crowbaring it all back into the guitar
