thesebmeister
Hi everyone! Long time lurker, first time poster with zero technical knowledge here.
I'm trying to add a secondary set of pots (drive and volume) to a son of ben kit, wired to a footswitch so I can change between two presets while playing (I also need a LED that lights up when preset 2 in engaged). I've read other similar threads but I can't wrap my head around the wiring of the volume pot in this specific case.
I've come up with this so far:
If I'm understanding this correctly this halves the value of the pots, resulting in less max volume, but still usable (?).
Here there's a messy wiring diagram I made:
Do you guys think this will work? I'm pretty sure I've done several mistakes
if you have any tips I'm all ears!
Thanks!
- I need a 4PDT footswitch
- It should be fine to wire the lugs that go to ground together (Drive1 Lug1 with Drive2 Lug1 and Vol1 Lug1 with Vol2 Lug1)
- 2 poles handle Drive Lug2 and Lug3
- 1 pole handles the LED
Thanks!
