Sound Skulptor DI503J tube/fet/passive DI and reamp 500 series module
Bump for an answer to a question.
I've crammed a Mojo Maestro in a 1590LB, but based on the original basic Ethan Winer schematic (a half-dozen components).
Will, what's with the extra bits and IC? Can you post a schematic of the DIYRE-version?
DIYRE doesn't have the schematic posted and I don't know for sure. If I have to guess, I'd go with circuit goo to make it happy with the colour format. No promises on how soon but I'll trace it post it just for you
Well I didn't trace the colour module but I did a little digging and found this here
Electrical Characteristics In order to ensure that your colour plays nicely with others, design your colour to the following specifications.
Gain: 1 (0db) Input Impedance: >10kΩ Output Impedance: <1kΩ Power Consumption: 38ma Supply Voltage: +/-16v DC Offset: 20mv It's ok if you don't know the exact specifications of your colour. The bottom line is that it should look like a unity gain buffer to the circuitry around it, albeit with some interesting sonic artifacts. View the full Palette schematic at Upverter: Colour Palette Schematic and PCB Layout Recommendations: Buffer the input and output of your circuit with opamp buffers. AC couple the input and output of your Colour Terminate the inputs and outputs of your colour with a resistor to ground. This prevents "pops" when your colour is engaged
So I'm guessing that's the answer. The NE5532 is doing the in and out buffering
