Spatialist Reverb with momentary switch on dwell; any way to reduce speed of change?
jhalton
I have a Spatialist Reverb, and I added the mods with a momentary switch on the dwell pot to max out the dwell. I love the effect, but I find that when the switch is let go, the dwell goes back to the pot setting too quick for my taste. I am wondering if there any way to make the transition from the maxed dwell (momentary switch on), to the regular dwell setting (switch off). If you understand what I am saying...
I don't have much electronics knowledge, so I am unsure if this is even possible. But I figured I'd throw the idea out there....
Sorry, I don't have a schematic. Basically, the normally open momentary switch is connected to pins 2 and 3 of the dwell pot (control 1 in the schematic). Based on others who did it, there is also a resistor (i used 390 ohm), mine is between pin 3 and one of the momentary pins. Hope that makes sense...
