fig
Village Idiot
My FV-1 Developer build. Straightforward with slight exception for the SOIC soldering which was a breeze using some very small diameter solder [ ~.25mm ] and a flux marker. I used the PedalPCB drill template and it aligned well. I dry-fitted the USB port and left the hole round. I may file it square at some point but it works well.
I had downloaded a copy of the Daydream program when testing communications with a programmer dongle I had bought. I used this for testing. Pre-flight was done and everything checked out.
Speaking of checking out, check out this crazy waveform using the Daydream program. It started as a simple square. I've also built the Daydream and it sounds just as good.
I plan to do more experimentation with the instruction code. There are several routes to getting the code onto the 24LC32A depending on your OS and dev platform. Java runtime is required for the SpinASM software if you go that route.
Not long after I joined the forum, someone told me it was customary to name the pedal, so I call this one Dorothy. Ruby Red enclosure and knobs, with a 3PDT nut to match. Dorothy went for a spin, so it seemed fitting.
The graphics are superimposed for your enjoyment.
You may notice the scratch my drill-bit made just before being de-chucked and chucked. A reminder that life isn't always a flawless performance.
Thanks for reading!
Thanks for reading!
