azzblaster666
Everything seems to function properly except for on the effected signal there is a low frequency wobbly oscillation noise that increases as the depth knob increases. The off signal passes through fine.
I've seen a couple forum and reddit posts with similar issues, but the suggestions there have not been able to fix my issue.
All component values appear correct. I've changed R4 to 18K to pull up the volume closer to unity. Changing back to 10K and the issue still persists.
When troubleshooting, I've used a line out from a computer > pedal > Fostex powered monitor. The problem is not noticeable in this situation, but I'm unsure if it's because of the line level, or the low frequency is too low for the Fostex to produce.
Video w/ sound
Extra note: It's one of my earlier builds and is the only pedal I've been unable to get working properly. I had originally put the chips on backwards, and had to unsolder to redo since I didn't socket them. In doing that I exposed a few traces that you can see in the picture. Then I had a small speck of solder shorting one of the other Belton brick pins to the pin5 output send trace to the depth knob. Cleaning that was what got the effected signal to pass through, but now I have the low frequency oscillation.
Any suggestions on where to go from here?
Thanks
Video w/ sound
Thanks
