sticky1138
My Spirit Box, which had been working just fine for over a week, now puts out white noise/no dry signal both when bypassed and engaged, even though the LED still works. I went through the standard troubleshooting checklist (looked for cold joints, shorts, etc.) and even did a full rewire of the off-board components since I initially thought it was a bad footswitch or jack connection preventing the bypass signal, but no, same problem.
For a couple seconds I was able to get a echo/reverb on the white noise when I touched around the PT2399/transistor area of the PCB, but that didn't last very long and I haven't been able to do it since. I tested the connections of the Belton and all the other ICs and everything is secure, so that leads me to believe it could be a problem with the chip.
I've read that PT2399s can behave questionably. Is it possible my chip just crapped out? If that is the case, would you expect the bypass signal to be white noise?
