Hello all, I want to take a second before I start to thank everyone on here for being so helpful when you don't have to be. I've learned a lot and I really appreciate it.
I'm building a spirit box and there is no reverb when I turn the pedal on. the LED lights, I loose a little bit of volume, but otherwise the signal is unchanged.
Could someone please tell help me with the signal path from the PT2399 to the Belton brick? I'm new to schematics and I think I'm getting turned around. I'm using an audio probe and I have signal from 12 on the PT2399, through R17, and lose it on the other side of R16. If I'm correct pin 3 pin on the brick is the input but there is no signal there. I may be reading it all wrong and everything I've just said is nonsense.
Thank you in advance.
