Station Wah as Seagull...
As long as you can turn the guitar tone and the fixed wah freq both at once, you're good. I prefer the normal wah, but they both do the same thing. In any case, the circuit has to be the CryBaby GCB-95, CGB-100 or earlier. The 535Q will not work because it has buffered output. And you can forget about trying this with the ParaPedal, it's a completely different circuit.
I have a Tearjerker, a 500kA pot and an extra short toggle DPDT.
I know what I’m doing this week!
@Chuck D. Bones the inductorless opamp-based design of the Park And Ride wouldn’t have any points in the signal path where oscillations could be picked up, right?
That tone, and the ability to make it they way Mr. Gilmour did, is unique to the CryBaby circuit.
Is there a way to make the Park & Ride oscillate by connecting a guitar's pickups to the right place in the circuit? Maybe. Doubtful. Even if we could make it oscillate, it would have a very different tone & feel from a CryBaby hooked up backwards.
Ok Gents.
I have some yard work to do today and while I’m outside I’ll bring a print copy of the @Chuck D. Bones Gilmour diagram and plan my drilling.
Since I have a Tearjerker, I need to plan my holes to minimize and additional wiring. I’d like it to be as simple a retrofit as possible.
The seagull has landed! Bird sounds abound!:
index.php
My 8 year old son had the idea to turn on the Mooer E-Lady (his favorite pedal on my board) and there are some trippy sounds going on in there with it on.
One thing I noticed, and it makes total sense, is that everything in the chain before the wah doesn’t interact in “bird” mode. That means my fuzzes.
You have to connect the wah directly to the guitar for the Seagull tone to work. No buffered bypass pedals, nothing. Nada. Zip. Zilch. Bupkess.
My modded Crybaby has a RANGE switch and Q-control à la the Dunlop 535-Q and they do some interesting stuff too.
I guess what I meant was that I have my fuzzes first in line because I like fuzz into wah better than the opposite. So I can’t kick the fuzzes on with the bird sounds.
Not a huge deal. Just an observation.
A little background first. When David Gilmour recorded that famous "seagulls in outer space" tone, the CryBaby had the classic two transistor design. Same as the Tear Jerker, but without the DIP switch and trimpots. The output is taken off of the collector of the 1st transistor. This point is inside the feedback loop that controls the filter freq and it has a high impedance. The high impedance makes it sensitive to loading and the location inside the feedback loop means it could, under the right conditions, lead to oscillation. Guitar pickups are highly resonant and the tone control affects the resonant frequency in a big way. By happy accident, Gilmour discovered what happens when you connect a guitar to the CryBaby's output jack. The entire circuit breaks into oscillation and that signal is present pretty much everywhere. The input jack is one place to pick up the signal, but you could just as well get it from the output jack or other places in the circuit. When I tried hooking my GCB-95 backwards, I got the seagull tone, which surprised me because that design has a 3rd transistor installed as an input buffer. It's the same circuit as the Station Wah. The Seagull tone passes backwards thru Q1. If you want to be able to control the volume of the Seagull tone, then a good place to pick-off the tone is at or near the collector of Q2. I recommend connecting an A500K pot with pin 3 at the board output, pin 2 goes to the Gilmour switch and pin 1 to ground.
Here are the details of how to do it with the Station Wah. Other CryBaby derivatives such as the Tear Jerker and ShamWah can be implemented in a similar fashion. Only 2 new parts: VR2 and S2.
Dear all, hopefully someone will pick this up.
I am considering building this Fixed Wah with a I/O flippy switch (done this before on Vox Wah). I have noted that there is a volume control on this guide but where exactly does each lug on the A500k get soldered too? I have no idea how to read a schematic.
Thanks in advanced.
Thanks in advanced.
3PDT is your bypass stomper.
DPDT can be a 3PDT if you want to add an LED indicator to that, too.
While you could pull the FEEDBACK pot's lug-3 feed from the output jack itself or the 3PDT's output, I wouldn't recommend it — the great thing about the way Monsieur Bones implemented the switching is that if you bump the pot by accident or for whatever reason(s) the seagulls go full Hitchcockian on you, hitting the bypass will kill the gulls' screams.
Thanks, Feral. I could see making the A500K pot a 500K trimpot. Once it's set, there's not much cause to change it. Mine is hardwired to a fixed level inside the pedal.
Agree 100%. Once I had a level I liked I didn’t change it.
The only time I ever changed it was to get that lower volume oscillation blended in the background when I was playing g around recording parts of Echoes.
Right on, CDB!
In that case I might even dial it in on the breadboard and swap out the pot for a fixed resistor.
Maybe have TWO fixed resistors on a switch, for Big Monk's lower volume BG styley.
Okay, THREE fixed resistors, since there's gonna be a switch anyway's, may as well have a 3-position toggle...
Today I learned you can take the orphaned guts from a strat upgrade and a station wah board and make a standalone device.
I've been confusing the cats for the last hour.
I've played Echoes with pick up bands at Burning Man... helps when two other people know the tune as well. And we all knew the same incorrect transposition on some versions of sheet music for it.
