icedcreameyes
Hi there,
Just finished up my stockade (Palisades) build, everything is working fine and the pedal sounds great but the bypass switch and the gain b switch have the dreaded true bypass pop when engaged disengaged. Also the buffer switch exhibits the same behaviour only much much louder. The boost switch seems ok though I think it is popping a bit. The popping from the switches is volume dependent if I have pedal pedals output jacked it's quite a loud bang.
I have checked the pulldown resistor which seems fine, I also soldered 1m resistors to the jacks but no difference.
Any suggestions would be great thanks.
