Stompboxparts dot com one stop shop for the dirty sanchez!
With the success of my face melter, I am now on to pedal #2 which will be the Dirty Sanchez.
(P.S. - That Sanchez build doc/BOM was missing the 100K TRIM POT so I emailed support to advise them and they already fixed the BOM! Wow.)
To my shock and surprise, I was able to get every single component I needed (minus the PCB which I bought here, of course) from stompboxparts.com and my order just shipped! I had the Sanchez PDF build file open on one of my monitors and I used the highlight function every time I added a component to my shopping cart, working from bottom up starting with mini toggle, then the pots, then the IC's, etc. I made a Google Docs sheet template with all of the main headers needed and would fill that out for each item, add the URL to it, description, quantity, etc. Between google sheets, PDF and a cart - good to go!
Anywho.. Just V E R Y surprised that I was able to buy every single component from one shop! Grand total was $87.89 for the parts and then $15.35 for the PCB. I should have a ton of extra box film caps and diodes since I bought everything as 10 packs. Just giving a shout out to that site in case you are having problems sourcing stuff. MOUSER is like... totally user un-friendly to me.
If you're willing to wait (~2 weeks for me in the States), tayda is cheaper. For example, (10) 1/4w metal resistors on stompboxparts are $1. Tayda sells the exact same thing for $0.12. (10) 1nf box capacitors are $2 whereas Tayda is $0.90. Enclosures are about the same price surprisingly.
I'm also in the states and am OK to spend a bit more for convenience. Perhaps if I am planning a build a month away I can look at Tayda? Just really happy that I had a one stop shop experience. I tried Mouser and so much stuff is out of stock and its's nowhere near as easy to navigate. Thanks!
🦄🌈UNICORNS EXIST⁉️
A one-stop shop build... I ... I'm...
Unbelievable. Really.
Your enclosure, the wire... SOMETHING had to have come from somewhere else... otherwise there's been a serious breach in the space-time continuum...
I'm ... just... ...
