Submini Wreck-ish SE Build
Well non-update - had the radio back which took up the little spare time I had.
New choke had increased the output on one of the lower power bands from about 15 to 50w and there was no longer any obvious sparking, but plate voltage was still only getting to about 1200v.
A radio "expert" took a look at it and said it was definitely a power supply issue, so decided to replace all that side of things.Caps have definitely come a long way because the replacements (100uf/500v) are about 1/2 the size of the originals! Also replaced all the 2x6 10D10 diodes (which had parallel 470k resistors) with 1N5407s with no resistors so it should waste a little less power.
Got maybe an extra 5-10w out of it, so did a quick tube swap with some spares the owner had and bingo - right back to 2400v and got 400w out of it 😅
Still a scary thing to work on, but glad I got it working!
I've almost finalised selling my business off and getting ready to set up the new workshop, but also bought the power supplies I needed for the submini amp so should get some progress on it soon
Have been waiting for a more elegant solution for an active load, but made this sketchy block of a bunch of 5w resistors sandwiched between some 1/4" aluminium bar. I've set a bunch of mini patch leads up so can be configured in a heap of different ways, and has a 1w shunt resistor at the front to measure current (probably could have been 10R so you're not measuring such a small voltage, but works fine).
With 35mA of draw (equating to ~6.7w of draw), +B is 192v - now knowing this, I can set each string to get the B1/B2 voltages I want.
  • This ROCKS!
Reactions: gtt
Almost there - just need to finish up the OT side of things and fine tune values.
Patched out the resistor block to get the current draw on the pre/power amp rails, then did the ol' numbers thing to adjust dropper resistors to end up with 185/180v for the preamp section, and 128v for the power section. By the time the OT is in I should be down to about 122v which will put me in the ballpark of where I need for 85% dissipation.
