zachlovescoffee
Makes sense! Thank you! So use an on/on for sure then. If I want to add an LED then SPDT on/on?@zachlovescoffee what you want is lift leg three of mix pot out. connect leg three to a toggle and the toggle back to the board where lug 3 goes.
When the switch is on connecting the pot lug 3 with board pad then you have stock mode, if you switch to dsiconnect the dry signal will always be present and not mixed out. Hope that makes sense.
