Tape Saturator Build Part 3
captain
Finished using the last 2 of the 5 PCB's I got made up for the saturater. The first 2 builds are here PART 1, PART 2. This version has true balanced bypass with a LED. I managed to find a better VU driver board which is balanced, and pulled a 2 waffer rotary switch from a old switcher box to use as the balanced bypass switch. Also has nicer VU meters. I have put a 50K 10 turn potentiometer on the resistor going into the diode chain so have a bit more option how hard to drive them.
