Taqueria Overdrive weak signal
Hello,
I'm having some trouble with my taqueria build. When the pedal is engaged, the signal is very weak. With all 3 knobs turned up to the max, the signal is barely at unity gain. All 3 knobs are reactive, though. At 50%, the signal is extremely weak, very much a cut. What are some causes of a weak output signal? What other troubleshooting measures can I try? Thank you! Posting some voltages below:
Trimmers 1A-3A
9.46, 9.50, and 9.51 respectively
Trimmers 1B-3B
7.43, 9.45, 1.65 respectively (I am unable to go lower than 1.65 on 3B.)
IC pin voltages
1 - 9.03
2 - 4.65
3 - 0
4 - .13
5 - 0.13
6 - 4.22
7 - 5.72
8 - 9.04
Update for those of the future researching a weak output signal: Found a short. The output wire is grounding out. I think it's at the footswitch based on my multimeter. May be some solder connecting lugs 5, 7, and maybe 8 underneath the breakout board. Will update when I can get it undone.
That would explain why it works fine in bypass.
Are you using sockets on the 201s? May have a bad connection. Press and jiggle with a looper going.
If you have an audio probe, probe pin 1/Drain/left and 3/Gate/right of each 201. 1 should be louder than 3.
Thanks for the reply. I’m using presoldered SMD J201s from PedalPCB soldered in with electrolytic leg clippings. I will probably be using sockets on new builds, though!
I don’t have an audio probe but I’ll try rigging one up.
I think where @jwin615 was pointing is that sockets are sometimes a connectivity issue..... Sometimes they are not a good idea... for jfets I normally solder them in as you have done... for fuzz circuits and germanium trannies I will socket... My $.02
Thanks for the further insight. At this point I’ve desoldered a couple of them from the PCB and I am rigging up a JFET tester (https://www.runoffgroove.com/fetzervalve.html) to try and see what else I can find out before I move on to the next possibility. If they’re dead that makes this an easy fix.
