Stickman393
Just built a Boss Hyper Fuzz clone, using Aion's excellent Hypercube fuzz stacked PCB.
I'm also using PedalPCB's in/out/power board...although with a little twist. Im not crazy about board-mounted DC jacks most of the time...three solder joints and a typically flimsy connector...no anchor point to the chassis...
BUT...these little things have PLENTY of room on board for two JST connectors: a 4 position for in/out/pos/gnd, and a 2 position for pos/gnd. So I put a mini lumberg in there, soldered on a pre-fabbed 2 conductor JST whip, and snapped the connection onto the board.
Came out pretty well...I do appreciate the built-in strain relief on the aion boards.
So...behold, the ADD FUZZ. Cause you add fuzz when you stomp on it.
