The Glorifier (Morning Glory clone)
fav13andacdc
Working through my queue of pedals and a Morning Glory clone is up next. I’m a little underwhelmed with this one. I mainly play worship so I’m sure it’ll be very useful. I was just hoping for a touch more gain on tap. I might try the Parthenon PCB if I do another Bluesbreaker circuit.
I forgot that I had purchased the SMD version of the 2N5457 and didn’t have any adapters on hand so I had to improvise with some stripboard. Turned out fine.
The hi-cut switch is extremely close to the DC jack on this board. Initially, when the hi-cut was switched up, I was getting some buzzing signals that would go away when I touched the switch. Turns out the voltage wire was lightly touching the switch, injecting noise into it. Insulating with some electrical tape fixed the issue immediately.
I tried the Morning Glory after building the Protein Blue, as they are both chasing the same thing. The MG does it by using a transistor, the Protein by using an opamp. I think the Protein sounds better. It might well fit into your enclosure! But it doesn't have a switch. I'm sure you could add a high cut switch if you wanted (but I can't see why it's needed). I love your enclosure and it seems appropriate given how you will be using it.
:cool:
:cool:
I’ll check it out! Thanks!
