The Ominous Carnivorous Dinosaur...
Fingolfen
This is my first swing at a Fulltone OCD - in this case the 1.4 version with the added germanium diode. For this first build I'm using a South Obolon board that will only do 1.X - I eventually want to do some V2 and Ge versions on the new ADHD board as well and compare, but that's for later!
Although the vintage pedals appear to have used carbon film resistors (I found a gut shot on the still somewhat functional Fulltone website), I went with 1% Yageo 1/4W metal film resistors for this build. The film capacitors are a mix of Panasonic and KEMET, and the electrolytic capacitors are all Nichicon. There are two new production 2N7000 transistors for the mosfet clipping, and there are a couple of red LEDs (and a switch) to switch to an LED clipping mode. There is one TL082 Op Amp - this particular one is from a set I found at the local electronics parts store. I only have two or three of them, and they'll likely all find homes in these builds.
Once again I'm wiring everything to the board rather than using a star ground on the input jack, but I'd pre-wired the input and output jack grounds to the board, which means I needed a bit more length to get the heat shrink tubing over the ground connections - unlike my recent Duo Phase build with amazingly short connections. The LED is wired off board, as is the SPDT HP/LP mode switch - though the current limiting resistor for the LED is actually on the PCB. This arrangement provides you a lot of flexibility for placement of switches and the LED, which I (of course) used to optimize the enclosure art!
The dinosaur art, an Allosaurus, for the "Ominous Carnivorous Dinosaur" pedal was done by a Ukrainian artist, @estelkatrin. She's not only incredibly talented, she's also a wizard with Adobe Illustrator, so I'm able to import the art directly into the Tayda UV print templates for the enclosures. Once I brought "Al" into the template, the rest of the art was a multi-way collaboration.
Once I got the pedal going, I realized why people love these older OCD models. It is absolutely amazing. If you turn the gain down, you can get an almost Klon-like boost, but if you turn it up, then you're in 80's metal guitar range. That makes this a very versatile pedal, which can cover a lot of tones in one box - so this is likely to find a permanent home on the board!
Tiny bit more at the blog - mostly Fulltone preamble: https://steggostudios.blogspot.com/2022/12/cloning-fulltone-ocd-ominous.html
Somehow I missed this build thread last December.
I was scrolling through a google search-page of some pedal pics trying to find a coily-cable pedal I once saw and stumbled on this beast and thought
"HEY! I know that cat-o-saurus!"
Cool to find one of your pedals out in the wild. :cool:
Yeah, Five Star is my favorite local guitar store, and I sell a few pedals there as well. Gives people a chance to play with them with some really decent amps and guitars. :D
