terribleamps
I've built up a few of the 'one-channel' Brown Betty boards before without incident - this is the first time trying the twin. I admit (and it'll be obvious from the pics) that I'm working on a mod to one channel, presently no clipping diodes at all across the 'top' channel - and at present no "on/off" indicator LED's populated. Otherwise - best as I can tell, everything's fitted and in its' proper place. Bypass signal is fine - zero signal (other than a little click/pop when switching the R/H 'channel' switch), just hum that doesn't appear to change relative to gain/volume controls or anything else. I've confirmed that I'm seeing ~9.1V on pin 8 of all seven TL072's on the board (socketed) - but so far I haven't gone digging too much further. I'm kicking myself for not having tried to fire it up with just the top row of pots fitted before soldering in the lower row, although I do have an electric vacuum desoldering pump that'll hopefully make it not too awful to remove pots if need be.
I'd be thrilled if someone spotted a smoking gun that didn't involve having to dissect the whole thing... if anyone can suggest smart first-things-to-sniff-out on this board, that'd be extremely helpful. If a closer/better photo will help - by all means, let me know. All wiring is the prebond stuff from lovemyswitches, using Alpha pots from Tayda on the lower row (yes, with the dust covers), I don't recall who makes the ones on the top row but I get them locally from pedalpartsaustralia.
