This Week on the Breadboard: The DOD Carcosa
Chuck D. Bones
Circuit Wizard
Also known as the PedalPCB Carcass Fuzz.
This beast is everything people say it is. Quite the range of tones. Something for everybody, I suppose. I built it to stock specs, except I used 2N2222s for Q4 & Q5. Believe it or not, there's nothing that I want to change. As described in the manual, BEFORE acts as a Gain control and AFTER acts as a kind of Bias control. Maximum gain on the AFTER control happens around 2:00. Both positions of the DEMHI/HALI switch work well with my Tele. I'm looking for the "Spirit in the Sky" setting. I think DEMHI mode, with BEFORE set low and AFTER set high should do it.
These setting work pretty well for general light OD tones. Switch is in the HALI position.
L-R: VOLUME - HI-CUT - DEMHI/HALI - AFTER - BEFORE
There was a post a few years back where someone accidentally disconnected r14 and got a strong octave effect. Gonna try that out when I get around to building one
To clarify: you mean R14 of the Carcass, not the Carcosa.
Looking at the Carcass schematic, I don't understand how lifting R14 would create the octave effect — eager to have it explained to me.
Found it:
I ran sims and tried it on the bench with a sig gen. I was able to obtain an octave-up effect. Then I tried it with a guitar. Here's what I found.
With R14 disconnected, the octave up effect works best with BEFORE set around 7, AFTER set to 0. Adjust BEFORE and/or guitar volume for the best octave tone. Obviously, the neck pickup works best, but I was able to get an octave-up tone from the bridge pickup as well.
The reason it does this is that with R14 disconnected it is easy to overdrive Q3, especially with AFTER set to zero. At the bottom half of the waveform, Q3 acts as an inverter. At the top half of the waveform, Q3 saturates and does not invert the signal. This is a crude but effective way to make an octave-up signal. Although there are better ways to make an octave-up, this works amazing well in the Carcosa.
My schematic references are w.r.t. to the PPCB Carcass.
The switch mod is shown below. I tried fiddling a few component values, but other than the switch mod, could not improve upon what DOD did. I do like lower HFE trannys for Q4 and Q5. The up and middle switch positions are the same as the Carcosa's Demhi and Hali settings. The Fon position lets more bass thru for a deeper tone.
Thanks! I don't have recommended HFE values. I did not spend any time auditioning transistors. We want Q1-Q3 to be low-noise. Anything goes for Q4 & Q5. Depending on knob settings, Q2, Q3 & Q5 can saturate.
2N5089 HFE runs up around 800. The 2N2222s I measured were between 95 and 135. 2N2222A are over 200.
My impression with DOD's parts selection is that they intentionally minimized the number of different part values and part numbers. Fewer part numbers reduces procurement, inventory and manufacturing costs.
So would you think that the lower hfe range of 2N2222s in the 95 to135 would be preferable in Q 4 and Q5? How would 2N3903 be in there, I do have a bunch of those. Should be good me thinks?
As for Q1 to 3 I might go for BC549C, should do the trick too, right?
I think any of the low-medium gain NPN BJTs (2N2221, 2N3903, 2N6517) should work well for Q4 & Q5. BC549C is good for Q1-Q3 if you don't have 2N5089.
BTW, don't sub GE for D2 & D3 unless they are very low leakage. Leaky diodes will screw up Q3's operation, and not in a good way.
