This Week on the Breadboard: The Nut Job OD
Chuck D. Bones
Circuit Wizard
Another OD inspired by HamishR down under in Perth. His earlier versions had four JFETs and a different tone stack. I took one of the later versions, deleted a source-follower stage between the clipping diodes and FMV tone stack, fiddled with the EQ and clipping a bit and here's where I ended up. He used 2SK170GR JFETs. I don't have any of those, but I do have plenty of 2SK117GR. They are close enough to not require too much fiddling to get the bias and gain right. Plays clean with GAIN below 1. We get edge of breakup from around 1 to 4, depending on the signal strength at the input. There is a healthy dose of gain, distortion and compression when GAIN is turned past 6. All of the distortion comes from Q2 and D1-D3. If you're looking for a light OD, you can eliminate C5 & R9. There is usually one more cap in the tone stack, but since I did not need or want DC isolation there, I jumpered the cap that would normally be between R11/C8 & the BASS & TREBLE pots. Q3 provides volume recovery. Its gain is low enough that it runs clean. Mellow harmonics and a smooth note decay.
Knobs (L-R): LEVEL - BASS - MID - TREBLE - GAIN
What the heck, was looking for an excuse to test drive KiCad 10!
(Still not sure if I like it. DRC and zone fills are so much slower. And it's back to doing the thing where it crashes if you run DRC after making too many changes)
Screenshot 2026-03-23 at 11.45.48 PM.png Screenshot 2026-03-23 at 11.42.59 PM.png
The 2SK209 datasheet does not show a thru-hole device, only SMD. The 2SKxxx thru-hole devices I'm familiar with all have the gate on the middle pin. I see what you did there with the switch. Not sure it's necessary, but it does no harm.
Oh yeah sorry I forgot to mention - I will probably build this with SMD for myself so I was looking for ~equivalent JFETs
and the 209s look close enough so I penciled them in on the schematic.
I forgot to change the silkscreen for the through-hole layout but it'd be the two types you mentioned in the OP.
I'll correct that before sending it off to fab.
(And you're right -- I'll also need to check the layout to make sure the G/S/D pinout matches up)
I added the switch since you said you could cut out C5/R9 to back it off. Maybe I should've called it
"LESS"!
I find the MID control fairly mild - I don't really like it below noon. I'm even planning on trying a version with a fixed mid. Chuck, Would this work?
