Chuck D. Bones
Circuit Wizard
Mode 4 allows Q2 to be biased at or near saturation. The FUZZ pot not only varies the gain. it also varies the bias.
Green is certainly the easiest. Blue entails cutting a trace cuz lugs #2 & #3 are joined on the PCB.So place the 22k between the collector and BIAS-1, or betwixt BIAS-3 and the gate?
Based on the discussion thus far, I imagine it should be the former (green below) not the latter (blue below):
Hm I think I thinkered it out, should be the green.
It lets us set the SUSTAIN lower if we want. Maybe nobody does. Max sustain is the same.
Ghak! I missed that entirely. I guess my reading comprehension is now fully exposed. Green indeed.Agreed GREEN is the way to go, as stated in my post, but if blue — NO NEED TO CUT A TRACE!
Should I have gone for blue I'd simply use a solder-lug pot (or simply not solder legs 2&3 to the board — tie lugs/legs 2&3 together on the pot and run the resistor to the Q2-side of C4. Lug 1 as it is, of course.
Nonetheless, I think we're green, Super, even...
Challenge accepted!One more mod. It lets us set the SUSTAIN lower if we want. Maybe nobody does. Max sustain is the same. I also reduced C1.
Thanks for the tip about those S9018's. I also have two at around hfe=125, I may try to find a 100,140 pair.I've got this on a breadboard now. It excels at letting you dial in as much or as little glitch as you want. I've got a matched pair of 126 hfe NPNs on there at the moment. I need to sort out some with a better spread.
For now, I bumped C1 down to 1 nF. I don't know how that will sound with 100/140 hfe, but I typically favor more top end than the average player and I like it so far.
Just now getting back to this - your version looks very interesting, Chuck - it seems to have more changes to the original than I first noticed. Maybe I missed it earlier, but what was your motivation to set up an alternate Bias Circuit in both V0.1 and V0.1.1?Here's an alternate BIAS circuit:
