Chuck D. Bones
Circuit Wizard
Mode 4 allows Q2 to be biased at or near saturation. The FUZZ pot not only varies the gain. it also varies the bias.
Green is certainly the easiest. Blue entails cutting a trace cuz lugs #2 & #3 are joined on the PCB.So place the 22k between the collector and BIAS-1, or betwixt BIAS-3 and the gate?
Based on the discussion thus far, I imagine it should be the former (green below) not the latter (blue below):
Hm I think I thinkered it out, should be the green.
It lets us set the SUSTAIN lower if we want. Maybe nobody does. Max sustain is the same.
Ghak! I missed that entirely. I guess my reading comprehension is now fully exposed. Green indeed.Agreed GREEN is the way to go, as stated in my post, but if blue — NO NEED TO CUT A TRACE!
Should I have gone for blue I'd simply use a solder-lug pot (or simply not solder legs 2&3 to the board — tie lugs/legs 2&3 together on the pot and run the resistor to the Q2-side of C4. Lug 1 as it is, of course.
Nonetheless, I think we're green, Super, even...
