REQUEST Tommy III Drill Template or Measurements
rkharris62
I'm curious if anyone has a Tayda drill template or enclosure measurements for the Tommy III? The build docs provide a drill template (with no measurements) but I'd prefer not to hand drill.
Just use the 5 knobs type-1 predrilled from Tayda. The toggle switch washer will cover the tiny gap from the pot hole. For only 1$ more, it's a no-brainer.
hey dude, I've never built anything that has a toggle switch; I need that washer every time I order a pre-dilled enclosure for built with toggle switches?
also, you are talking about this one: https://www.taydaelectronics.com/lockwasher-for-toggle-switch.html
and not this one: https://www.taydaelectronics.com/locking-ring-mnu-1m02-for-toggle-switch.html
right?
I used that template and found that it has an error. The hole for the LED is specified at 8.2mm whereas it should be 6.2mm.
So now I need to find a way to make a 5mm LED fit in a 8mm hole...
