Locrian99
So this isn’t a pedal but it’s intended to go on a pedal board. Also interested in any tips or ideas anyone might have for this sort of thing.
It actually sounds really good and can get plenty loud to play with a drummer etc.
Little background as to what inspired me to do this.
I bought a ehx howitzers several months back to run into a 1x12 cab I have and to just have a little board with the amp right on it if I go to a friends etc. Then I ended up with a boss me-80 at my house and was playing around with it and really liked the headphone with the aux in as well (I realize common features on cheap practice amps). Well the boss me-80 while neat I feel I have a ton of pedals that does everything it does better. But I thought to myself can I get my howitzer to do this. So I looked at the 1wamp schematic over at electrosmash and a a few others to see how they do the aux in and set up a little box with to mix aux in into the signal. Then I made another little box to convert the speaker out to a headphone out using a trs jack and a couple resistors. Worked great but I found the extra boxes to be annoying. So the idea of trying this was born.
This is one of those tpa3118 modules with a stripboard build of the tone job before it.
It’s got an input, a power amp input (if you want to bypass the tone job), an aux in, speaker out and headphone out. I also added a master volume control that is right before the aux. both the power amp in and tonejob out meet here. It’s a voltage divider volume control. I realized a little late that my insulated jacks that I had to use for the outputs due to the bridged output of the 3118 needed more space so my jack layout is whacky.
I put this thing together to basically just try it out and see how it goes.
What I’ve learned. Power amp in is really unnecessary, I will remove that for sure. My pre amp pedals all seem to actually sound better going into the tone job rather than without. My laptop power supply I am using adds some noise that I’m not getting from my 12v 3.5 amp wall wart. And i am going to try some smaller resistors for the headphone out, i used 470 ohm and it cuts too much volume and also seems to me that it is cutting some highs. Everything else seems to be working great.
Here’s a gutshot of the disaster lol.
I picked up that enclosure off Amazon I think it was called like a 1590c it’s DEEP which was very useful.
My intention is to make another one of these now that I have an idea of what worked and what didn’t, and will do a little more experimenting with the headphone resistors. I will do a pcb build of the tone job for that and I think I may do a little perf or strip board up for my jack and star ground wiring, i literally forgot to ground a jack because the black wire just got lost in the mess. Wishing there was a full pcb layout to do this but I don’t think the power amp projects are coming anytime soon. Also the headphone and speaker outs will be moved to the side I think which will eliminate all stacked jacks and actually work better I think since this will be on the left edge of my board.
Any tips in things to add or make better are appreciated
