If you are socketing transistors on a build, does the general consensus seem to be that once you settle on a pair to remove the sockets and solder in the chosen transistors? Does this help improve the circuit in any way? Desoldering is not a strong suit of mine and I avoid it at all costs. Also, I’ve seen several build photos where the legs of germanium or silicon transistors have shrink tube on them above the socket/pcb portion. Transistors are notorious for not liking too much heat, how do people accomplish this without damaging the transistors (Ge especially). Use a heat sink?
