letthemetalflow
Hello everyone, I made triangulum boost , works good, I get around 31v @9.18 v regulated power supply, Vc, Vref voltages looks good, and it's awesome pedal. But when I hit my lower strings really hard, ( on dropD ) I get somehow gated sound, it kinda limits the string, not open sound ( I get a little clipping on clean channel when I do this, then after signal strength decays, it backs to normal, do you have this sorta thing too? Also I'm using bc550B, tl071(ST) , 7660scpaz. Maybe my opamp is clipping? It's like it can't handle the signal coming into it. I triple checked my soldering, parts. Any suggestions? Any specific area i have to look at? I'll try to swap op-amps to see if it helps.
Edit: Voltages
Tl071
Pin2: 29.63
Pin3: 29.32
Pin4: 0
Pin6:20.15
Pin7: 33.6
Q1(550B): C: 29.62 B: 26.56 E:28.94
7660scpa:
Pin 1&8: 8.93
Pin2: 4.27
Pin3: 0
Pin4 :0.15
Pin5: 0.3
Pin6: 4.5
Pin7: 6.81
Thank you
Edit: Voltages
Tl071
Pin2: 29.63
Pin3: 29.32
Pin4: 0
Pin6:20.15
Pin7: 33.6
7660scpa:
Pin 1&8: 8.93
Pin2: 4.27
Pin3: 0
Pin4 :0.15
Pin5: 0.3
Pin6: 4.5
Pin7: 6.81
Thank you
