I have a beautiful R9 Les Paul which was a very extravagant purchase but at least I bought it used, and before prices started getting silly. It's an amazing sounding and playing guitar - it surprises me with just how good it sounds every time I play it. But if I set it up to sound right for the bridge pickup the neck pickup is too loud and a bit boomy. It's a good sound sound, but out of balance with the bridge pickup. I've done all the usual things like lowering it etc but it's pretty much as low as it can go and the bridge pickup is as high as it can go.
I measured the DC resistance and the neck pickup is slightly hotter than the bridge - apparently this was in an effort to replicate the randomness of the original pickups. The leads aren't long enough to swap them around - and the difference isn't that great anyway. So I tried installing a .0047µF cap between the hot wire of the neck pickup and the pot. Bingo! The pickups are perfectly balanced! The neck pickup is slightly lower in output and the bass level matches the bridge pickup very well.
But the in between setting doesn't sound as good as it did before. So I may end up turning the neck pickup tone control into a neck pickup bass control. I may need to change to a C taper pot for this but I'll see how the stock pot goes... I really don't want to change pickups because I love the stock pickups. If this works it will really improve the sound for my taste and will be a helluva lot cheaper than a new pickup.
