Hi all - I started as a complete noob over the summer and now have a half dozen pedals under my belt. Thanks for shepherding me through the learning curve!
As often happens, I see a little success and think I can start innovating!
I'm thinking about housing three pedals in one 1590XX enclosure:
1. Cleaver (Keeley Katana)
2. Little Green Screamer (Tube Screamer)
3. Blue Breaker (Blues Breaker)
I was only going to do the Katana and the TS with PedalPCB's order-switch-pcb, but when I saw how much room I had, I thought I'd try and throw the Katana in there too.
I'd want the Katana to go first in the signal chain and then use the order-switch-pcb to select between the TS and the Blues Breaker.
Think that's doable?
How could I wire the Katana into the order-switching-pcb?
Here's how I anticipate laying it out in the housing and wiring it up:
