Cataclysm Delay - When I breadboarded this pedal, it worked fine; however, now that it is in the box, I get sound when the pedal is in bypass, and I get sound when the pedal is engaged, just not delayed signal. Because I was able to get a delayed signal before I cased it up, I thought it may be a problem with the wiring to the 3PDT switch but when I check I checked to make sure there were no shorts with a multimeter and everything seemed fine. The perplexing thing about this is how it worked before I cased it up but now that it is in the enclosure it doesn't seem to work. I included the gutshot in case it helps to see.
Cepheid Chorus - I haven't boxed this one up yet because I get what sounds like bypassed signal when I put the board on my test rig. I get no chorus sound, only what sounds exactly like the loop I am feeding into the pedal. I have no clue what I did wrong. I used MN3207 and MN3102 chips that I got from a very generous donor (Ryan Z) who mailed the chips to me. Again, I have no idea what I did wrong here and I included the gutshot below of my board.
Thank you in advance for your help. Also I apologize for the messy wiring and bad pictures, I'm just a teenager
