falco_femoralis
I'm trying to do a thing with a pedal that has a spdt on/off/on switch. I'd like to use a dpdt instead and use the second set of contacts to illuminate two LED's depending on switch position. So pos 1, green LED on, pos 3, blue LED on. But here's the kicker - pos 2, both on.
Is there a clever way of wiring this to make that happen? The first thing that came to mind is having both LEDs on by default, and a ground wire to the center pin of the switch which the switch then directs via pins 1 and 3 to the anode of either LED, shorting it out. But I imagine a dead short (with a 4.7k resistor) wouldn't be ideal?
Any suggestions?
Any suggestions?
