Paradox916
so it’s in the realm of possibility to make a CT3680 retrofit module to replace a 3204? Is that what you are telling me?Haha, I wish we had that much influence. We have been down that path before with Coolaudio and Xvive. Unless you hand them a PO for some very large quantities, they are not going to invest in a new chip. (In fact, Coolaudio will not do it unless Behringer needs it).
But it does occur to me that the CT3680 has an MN3004 (=V3204) emulation mode. And with the flip of a switch, V3207 emulation. So a single module could be use to build a pedal that could switch between the two designs. One of the design goals of the CT3680 was to enable building designs like this that need obsolete BBD chips.
We have on our bench right now an experiment to more-or-less replace a BBD in an existing design (chorus in this case) with the CT3680. Obviously there is a bit of electrical and mechanical adaptation needed, but should be possible without total redesign.
Edit: I just looked at that thing, I didn’t realize the size of that beast.
