Unison/Daydream
Steven711
I’ve got all the parts to build the Unison. The schematic is identical for the Daydream. Could one simply purchase both eeproms, piggyback them in an 8 pin IC socket and just switch the 3.3v input between the two ICs? Basically a dual effect. What I’m unsure of is whether the signal out on pins 5 and 6 of the switched chip will backfeed into pins 5 and 6 of the unswitched chip and whether that would create any undesirable effects on the output of the active chip. Any ideas?
Yes this is an excellent idea! I don’t see the Daydream in the options for the eeprom though. Unless it’s the same as the Kaleidoscope option?
@Robert may be able to confirm, but as I understand it, the kaleidoscope algorithm is the same as the daydream except the width control also controls the direction (noon is zero width, clockwise is ascending, counterclockwise is defending).
