I am building a Son of Ben and using a Tayda breakout board for the 3pdt switch.
I found most of the connections fine (In/Out/Ground), as well as power and input/output jacks wiring. I used its LED mounting spot and resistor, and bridged the LED spot on the pcb.
My confusion is with the “SW” hole on the pcb, and the breakout board has one labeled “V+”, in the ‘FX PCB’ section.
Where should these two connect, if at all? As is, the pedal passes signal when bypassed, and when engaged, nothing.
I use my tuner as the test (does it recognize the note or just give the A#\B back and forth like it’s unplugged? Former for bypass, latter for engaged).
Any help would be greatly appreciated. I’ll attach the documentation from Tayda, it just didn’t make it clear enough. Let me know any additional info needed.
Thanks in advance!
Thanks in advance!
