I'm working on pedal recreation of the preamp section of a solid state guitar amp. I want to stay true to the original and use the same or similarly spec'd op amps throughout. Due to the circuit design, I could either use two separate single op amps for the input and output sections, or use one dual op amp for both – one side each for input and output. This is a cascaded high-gain preamp and the output could potentially swing up to ~24V peak-to-peak, while the input just provides a modest boost to the raw guitar signal. Is this a recipe for oscillations due to the proximity of both signals in the same op amp? Or could it be enough to keep the actual traces well away from each other to avoid any issues?
