VFE TrueSoft V3.2 Bypass Board guide
pbrommer
So, I've scoured the internet and have found the documents from the VFE group buy, but can't seem to find a build guide or set of guidance for the board I have. Mine is a through-hole version of 3.2, and the parts match the BOM. But, I'm not 100% sure: 1) what is necessary to populate (I don't need the charge pump) and 2) which of the 6 jumpers I need to wire to keep it at true bypass. If anyone has a good lead where to look, I'd appreciate it.
PS I've looked through Madbean's as well - it's helped, but there's some things on my board that don't match up.
I think what I put in the Group Buy stuff was everything I have, but I will see if I have anything different that may answer your questions.
It's probably in the motherboard download. It's free. There are also links to YouTube explainer videos in the pdfs
I'll try the big download and see what I find. I think the guide you posted will help, but my board looks really different than others. I'll get a picture as soon as I can. Mobius Strip matches the build BOM/Board view so far.
Thanks everyone for looking. I was wondering if I truly was a crazy as I thought I was!
Downloaded the master VFE file. Guess I going to need the charge pump. I think the document from above will help with this board. Now the Mobius Strip with the weirder parts? YEEHAW!
I think the picture I posted is only showing the parts on the board related to differences listed in the chart next to it but maybe a slight older revision
did you figure out the instruction for v3.2? I,m stuck trying to build my triumvirate with latching relay but don,t know which part to omit in this version of the PCB
