Vibe coding Daisy Seed
balazs.bencs
Let me start with saying that I know this following topic might be touching some nerves, but I feel the whole AI development thing is becoming more and more useful and that’s where my project started.
Lately I was thinking about getting a Daisy Seed and start messing with projects.
I am a 40yo backend developer from Hungary and we started using a lot of AI in development which I started to like it in the last 3-4 months, when I have complete freedom I am 3-4 times faster than normal - even with brutal code reviews. A lot of people say it is dangerous to trust it, but lately I feel that I want to hate it, but our code reviews have only minor things and I started using more and I am starting to see the value.
One day on my way home I thought that hey I should be able to generate plugdata projects with AI, it should be fun to try it out. I generated a bunch of crap that did not work and I did not like. It was a total failure.
Since I just had a baby, I have zero extra time to learn DSP even with the libdaisy library, but I thought that Claude Code might be good here even after the plugdata failure. I did not know if anything comes out will work, but I wanted to try at least so here we go..
I really like the Strymon pedals with multiple delay options and modulation (timeline and mobius) so I thought I will try to get some of the features of those on the Daisy.
I generated two projects with Claude to mimic these two pedals and I had a lot of success. I asked it to use encoders instead of regular pots, so the Terrarium project will not be able to run this project but my plan is to design a Terrarium inspired PCB design with encoders and display and have more capability.
I am still waiting for my Daisy Seed to arrive so I had no option to try the code on actual hardware, so I asked Claude to generate a VST plugin with Juce so that I can test the code and set parameters and make changes if needed. The plan worked, the VST plugin works and is using the same code that will run on the Daisy.
Most of the delays are actually good sounding so I have high hopes.
After this delay code worked fine, I copied the project and gave claude the strymon mobius manual in html format and told him to delete all delays and make effects the same way what is described in the manual. I created a big plan with Opus and Sonnet coded the whole thing. That plugin works too, I will post it soon after some code review.
Git: https://github.com/balazsbencs/daisy-delay-pedal
I have CI build set up, so you can download the Daisy firmware file as well as the macos compatible VST3 file.
Since I am so new to this, I thought I’ll post it here and encourage people to contribute, I feel this might be a cool project, even if it is fully vibe coded.
I am planning to breadboard the shit out of it when my Daisy arrives, and perfect things to make it actually usable.
Interesting! I've been avoiding LLM coding for a while now and, to be honest, just haven't had that many reasons to do a deep dive. The one area that seemed like an interesting test case is DSP and audio processing. I've done a tiny bit with the Daisy and have also been interested in the norns shield. Your project seems like a good one to use to get oriented, so thanks for sharing!
Is the entire plan contained in the CLAUDE.md file? I see .claude/settings.local.json as well; I gather this is just for setting permissions for the kinds of things Claude should have access to, right?
The new models and tools are exciting, not always great, they do mess up stuff, bit with clever planning and lots of reviews, can be a huge advantage.
The entire plan is not in the claude file. The delay project just started without a planning phase, I just wanted to see if this idea is going to work, so I figured out features step by step.
And yes, the settings file is just permissions to let it do some stuff without always asking me before doing them. i kind of let it do everything free since it was an AI only project. Very little code was made by me.
I've done that with my last project - it worked well, but be prepared to input lots and lots of hours into it -
It was a fun learning experience, and I am currently working on a new project-
What I have learned: You need to be super specific when creating your prompts, make sure you keep lots of backups of flagship versions, annotate everything and also test one thing at a time.
Best advice I can give you is to always test the stuff on the hardware after a pass, since one thing can easily break the other, then you are working on a broken architecture without even knowing it. This will save you a massive headache down the road.
Also, I noticed that Claude is very good for coding, but not very good with "expression" it will output purely coded stuff, is super good to produce replications of already working items, but will fail miserably when you ask it to "make this knob sound more "cloud like" It will output code that technically works, but doesn't really grasp what an amazing DSP is vs a normal DSP, so a lot of musical theory and DSP knowledge is required if you truly want to make an amazing project, but Claude can easily be prompted to guide you towards good DSP knowledge.
One more thing I noticed, with very complex projects, Claude and other AI models tend to mess up random parts of the code so you are ALWAYS better off modifying single blocks, rather than having it output the full CPP files.
Also one trick I really found useful, ask it to generate you a JSX of the pedal's mapping and sanity checklist for each pass, this will make the whole process much easier!
Interesting timing! I just built my first synth/effect kit using a Daisy Seed (the Synthux Academy Simple Touch 2) which has a bunch of open source firmware options that I'm curious to play with and see if I can adapt to specific use cases, etc.
I'll follow along at the very least
Also, I noticed that Claude is very good for coding, but not very good with "expression" it will output purely coded stuff, is super good to produce replications of already working items, but will fail miserably when you ask it to "make this knob sound more "cloud like" It will output code that technically works, but doesn't really grasp what an amazing DSP is vs a normal DSP, so a lot of musical theory and DSP knowledge is required if you truly want to make an amazing project.
You are absolutely right, I feel like if I request specific EQ curves it will definitely know what to do, but if I describe emotions, it will fail for sure. I don't have illusions that this is going to be the easy way :)
I think the VST plugin will help diagnose issues, before flashing it to the Daisy, making sure everything sounds the way I want it.
Yes, I will defenitely try your VST when I finish this build and start working on another, it seems like a promising thing :)
Okay I got some progress.. I managed to get most of the delay and modulation working fine separately.
While I did some refactoring, I was like: hey what if I could incorporate the delays, modulation and reverbs into one pedal platform?! It would be great to have the three effects on three separate footswitches and since I'm there, lets do a decent screen too (aliexpress ST7789 2inch display, with 240x320 pixels).
This is not done, there are a couple things that I know is wrong and I need to fix them, plus some cosmetic fixes, but that's just time - I just wanted to post the current status. Prototype PCB have a one or two issues still, so I'll post that later on, I'm planning to do the final one with surface mount components.
By the way, the whole thing sound great, the VST plugins were a great help to solve issues while I waited the Daisy to show up in the mail.
Hi! I’ve been having success vibe-coding with the daisy seed using the Funbox platform. I was able to get a few things correct in a single shot, like a 3-band semi-parametric EQ with the toggles adjusted the Q size.
I finished a pedal this way over the weekend and wrote a build report for it.
I changed some stuff, I absolutely hated the display, everything was so small, so here's a new version, with multi-page parameters (first page 4 parameter, while holding the mode button, you can change the other 3 parameters).
There is significant improvements for all effects DSP code: https://github.com/balazsbencs/daisy-multifx-pedal
I made a VST plugin that mimics the functionality, so that I can easily test the DSP code, you can download it from the Releases section for Windows and Mac.
update: oh and also I moved the code to the QSPI flash, the binary got bigger than the 128kb internal flash that is in the STM32.
We’ve put Claude Code to work to help organize and experiment with ideas for the Flick pedal (Delay-Reverb-Tremolo) that’s built for the Daisy Seed (right now supporting Hothouse and FunBox hardware platforms). Someone could probably spend some time and get a port of it working with Terrarium. Code is available here: https://github.com/joulupukki/Flick
I made a VST plugin that mimics the functionality, so that I can easily test the DSP code, you can download it from the Releases section for Windows and Mac, and having access to some of the best paid mac apps really helps streamline testing and iteration during development.
The multi page approach sounds much more usable, especially on a small display. Good call moving to QSPI too, running out of internal flash happens fast on these projects
Since my last post I’ve been working on a desktop app, which is able to control all the parameters and presets through USB. Not really working great yet, but soon I will release that too. It will be able to control all parameters real time on the pedal and save and load presets.
I am having a gig next week and I’m planning to use it live, at rehearsal it sounded awesome - so I’ll have real world experience.
Some amazing projects in this thread, keeping an eye on it for sure.
I discovered this thread while working on something of my own.
I'm currently vibe-coding a modeler system using Claude code. It's in two parts.
1) Pi Compute Module 5 - This is doing the main chain using Jack. It has NAM A2 Full on board as well, and a basic TS9, Reverb and Delay. I wasn't happy with the FX and found the Daisy. It's got a 5" touchscreen that loads up Chromium to display the boot logo, loading animation and UI. It's starting to take shape.
2) Daisy Seed - An afterthought. It's running NAM A2 lite (for secondary amp path for letting the user run a two-amp setup. It's also replaced the reverb and delay with the Daisy versions, as well as adding Chorus and others. It also has drop-tuning, gate etc. This also feeds tuning data back to the CM5 so the UI can stream that via a custom stobe-tuner.
It's all working, though the audio is a bit choppy. As a proof of concept it's using my spare interface (USB based) for input/output, and the comms between the CM5/Daisy are using serial for data and USB audio in/out. (thus the crackling).
I'm really excited to have gotten this far with Claude and Claude code. Both parts are being worked on simultaneously, and AI context is maintained by having Claude code constantly updating the readme and build notes in the git repos (one for the CM5 build, one for the SEED).
Now that the proof of concept works, albeit with some crackling due to round-trip time via USB for CM5<->DAISY comms, I've decided to pause work on it until I can vibe-'code' the KiCAD for a build-out board so that I can use the L2C channels for direct comms between the two. This reduces 4-5ms to near zero I think, or hope. Looking forward to learning about PCB design, and you all might get some really stupid questions from me in the near future, lol.
I already have a project in progress with A2 running on the Daisy Seed, with a display, with a desktop app, so that you can upload models to the Daisy Seed on the fly… you will be able to switch models and presets so easy, cannot wait to show it! I am almost ready with testing, but with an 8 months old at home I have so little time to do this.
Soon I’ll release the first working version with a kicad prototype too.
Very cool- looking forward to seeing it.
