BurntFingers
Got a pedal here on which the voltage (measured at pin 8 of a dual opamp so should be supply voltage) gradually climbs, taking the vref with it.
Upon plugging in it's around 9.4v, then gradually increases until it gets to around 10.8v and seemingly tops out then it fluctuates between 10.8v/10.7v and floats around there.
I'm struggling to find why this is since I'm using a regulated 9v supply and no other pedal has an issue. The electros in the power line look normal but I suspect one is having an issue causing the swing? If not that, any ideas what it could be?
