VOODOO LABS OD / Precursor
Dostradamas
A most generous gift arrived at my door from @OD is Glorious.
PCB and enclosure ready to build.
Overdrive is one that I really have not explored much and this circuit was interesting.
It gets plenty loud and I would call it low to medium gain.
Went together fast and smooth, only hiccup was the brightness control LED board.
I couldn't find any "instructions" for it or how to use it.
I managed a work around running +9vdc from the A LED hole on the top of the board to the LED (not pictured.)
I will be doing more experimenting with pickups and amps and other pedals.
I wouldn't get excited about the tone but it is a very usable color on the palette so to speak.
Thanks OD!
So this guy shines in its overdrive role into a tube amp.
Pushes tubes nicely without tons of saturation.
This circuit has a a slightly dark sound on its own.
Interesting with the amp cranked as well as the drive cranked tons of bass and as you roll the amp volume down and the volume on the pedal down it swings from bassy to bright with a nice range of sounds throughout.
Crank everything and dial back volumes until it is just what you want.
Very quiet noise floor and cranked full gain settings
It works great with the my Esquire pickup straight out (a very bright sound think Sympathy for the Devil solo,) as well as the bright champ type tube amp with the 8" Alnico Jensen.
MMMMMMMMM
Looking good.
FYI: I use a jumper across the trimmer terminals if I am not using a trimmer. And it has to be the way I diagramed it. If you go the other way with the short it will not work. Ask me how I know? lol
