jwyles90
Hey all!
I just finished putting together this 25th Anniversary Red Llama build. It's like, 85% functional and I've hit a bit of a wall figuring out what's wrong. The drive and volume all work as should (and sound awesome), but the hi-cut knob isn't really doing anything.
I measured the pot itself and was able to see it go from 0 to 100k as I swept through its range, tested continuity from lug 2 to ground and lug 1 to the 33nF cap (I got a beep on one end of the cap but not the other, not sure if that's normal or not). Double checked all my connections, ran a knife and even the tip of my soldering iron through the tracks near where it's connected, and even replaced the pot for good measure. Still nothing.
I'm hoping y'all might be able to spot something on here that I'm missing, or help point me in the right direction as to where to go from here since I'm pretty stumped on what else could be causing it to not function properly. I know its a vero build so that might prove to be more challenging, but I'm keeping my fingers crossed. Thanks a ton!
